IAP-225 wifi-uplink and no client IP
  • 1.  IAP-225 wifi-uplink and no client IP
    Posted Aug 21, 2020 08:53 AM
    Hi!
    New airhead here.
    I've set up an IAP-225 as a standalone AP with wifi-uplink.
    This works fine, it connects and all. But when i try to connect clients to it, they won't get any IP! Is this by design? I have a remote DHCP server which i wanted to use, but i think i might need to add one in the AP instead? And how would i setup this and get my clients to communicate with the rest of the network?
    So i have a router---wifiap(netgear with dhcp) *** iap225 *** clients
    ***= wireless.
    Thanks!
  • 2.  RE: IAP-225 wifi-uplink and no client IP
    MVP EXPERT
    Posted Aug 21, 2020 09:44 AM
    What is the client VLAN configuration within your Virtual Controller? Is this controller assigned (e.g hidden behind the IAP) or static and tagging the VLANs accordingly? Does the router---wifiap(netgear with dhcp)  support VLANs?
  • 3.  RE: IAP-225 wifi-uplink and no client IP
    Posted Aug 21, 2020 01:02 PM
    Thanks for getting back to me!
    client VLAN configuration isjust default meaning i haven't set anything up.
    I guess this means it's hidden behind the AP? What i think is weird is hat it works perfectly fine with ethernet uplink but not wifi. However the docs say that i need to setup a dhcp server on the ap. Is this correct?
    Edit: It seems wifi uplink is stuck at probing. And eventually the AP drops the connection (both leds goes off on 2.4/5ghz)
  • 4.  RE: IAP-225 wifi-uplink and no client IP
    MVP EXPERT
    Posted Aug 21, 2020 02:59 PM
    Sounds like the IAP uplink is the issue. Do you see the IAP as a client? What is the WiFi uplink priority configured within the IAP? Is it at the top?
  • 5.  RE: IAP-225 wifi-uplink and no client IP
    Posted Aug 21, 2020 03:47 PM
    Well here is my config, if you spot anything wrong please correct me
    Anything else i should look out for?
    version 8.6.0.0-8.6.0
    virtual-controller-country US
    virtual-controller-key #######
    name Aruba-225
    terminal-access
    clock timezone none 00 00
    rf-band all
    allow-new-aps
    allowed-ap 18:64:72:cc:####
    arm
     wide-bands 5ghz
     80mhz-support
     min-tx-power 9
     max-tx-power 127
     band-steering-mode prefer-5ghz
     air-time-fairness-mode default-access
     channel-quality-aware-arm-disable
     client-aware
     scanning
    rf dot11g-radio-profile
     max-distance 0
     max-tx-power 9
     min-tx-power 6
     disable-arm-wids-functions off
     free-channel-index 40
    rf dot11a-radio-profile
     max-distance 0
     max-tx-power 18
     min-tx-power 12
    ip dhcp pool
     subnet 192.168.2.0
     subnet-mask 255.255.255.0
     dns-server 192.168.1.1
     domain-name ArubaDHCP
     lease-time 2880
    syslog-level warn ap-debug
    syslog-level warn network
    syslog-level warn security
    syslog-level warn system
    syslog-level warn user
    syslog-level warn user-debug
    syslog-level warn wireless
    hash-mgmt-password
    hash-mgmt-user admin password hash 103310ea020c8c9c67e1b85a70002d1f4b7b7e99e97eb4cd9340c37c1de#####91
    wlan access-rule default_wired_port_profile
     index 0
     rule any any match any any any permit
    wlan access-rule wired-SetMeUp
     index 1
     rule masterip 0.0.0.0 match tcp 80 80 permit
     rule masterip 0.0.0.0 match tcp 4343 4343 permit
     rule any any match udp 67 68 permit
     rule any any match udp 53 53 permit
    wlan access-rule Aruba
     index 2
    wlan ssid-profile Aruba
     enable
     index 0
     type employee
     essid Aruba
     wpa-passphrase 8aa7c0f52ee9dedd89d875f18c#####fa25d2189
     opmode wpa2-psk-aes
     max-authentication-failures 0
     rf-band all
     captive-portal disable
     dtim-period 1
     broadcast-filter arp
     dmo-channel-utilization-threshold 90
     local-probe-req-thresh 0
     max-clients-threshold 64
    auth-survivability cache-time-out 24
    wlan external-captive-portal
     server localhost
     port 80
     url "/"
     auth-text "Authenticated"
     auto-whitelist-disable
     https
    blacklist-time 3600
    auth-failure-blacklist-time 3600
    ids
     wireless-containment none
    wired-port-profile wired-SetMeUp
     switchport-mode access
     allowed-vlan all
     native-vlan guest
     no shutdown
     access-rule-name wired-SetMeUp
     speed auto
     duplex auto
     no poe
     type guest
     no dot1x
    wired-port-profile default_wired_port_profile
     switchport-mode trunk
     allowed-vlan all
     native-vlan 1
     shutdown
     access-rule-name default_wired_port_profile
     speed auto
     duplex full
     no poe
     type employee
     no dot1x
    enet0-port-profile default_wired_port_profile
    wlan sta-profile
     essid NETGEAR16
     cipher-suite wpa2-ccmp-psk
     wpa-passphrase f8077c5eaa4eb1db5517####789e134ce8b768cfca2cb
     uplink-band dot11g
    uplink
     preemption
     enforce wifi
     failover-internet-pkt-lost-cnt 10
     failover-internet-pkt-send-freq 30
     failover-vpn-timeout 180
     uplink-priority ethernet 9
     uplink-priority wifi 8
     uplink-priority cellular 10
    airgroup
     disable
    airgroupservice airplay
     disable
     description AirPlay
    airgroupservice airprint
     disable
     description AirPrint
    cluster-security
     allow-low-assurance-devices
  • 6.  RE: IAP-225 wifi-uplink and no client IP
    Posted Aug 23, 2020 09:43 AM
    I cannot see the ap as a client, should I?
    Thanks!
