Occasional Contributor I
Re: IAP-275 with OS 4.2 , Solid red Led and showing highest noise on RF dashboard
This had to be RMA'd.
Super Contributor I
It should be noted that the 275 requires 802.3at power (the cisco 200 switch only supports af) and needs lldp enabled. Like the OP you should use a power injector if you have a switch that's only capable of af power, and more times than not the easiest way to make that work is to disable PoE on the switch port.
ACDX #419 | ACMP |
