IAP 315 / vc not showing mobile website
  • 1.  IAP 315 / vc not showing mobile website
    Posted Sep 21, 2019 05:40 AM
    Hi Airheads,
    I've been breaking my brain over the following issue. I have 2 IAP-315 in my network, and all is working well, however; when I try to access the virtual controller from my phone; either through instant.arubanetworks.com:4343 or directly through IP address, I get the desktop version of the site:
    My colleague, who has a similar setup (but with different IAP's) gets the mobile website:
    I've downgraded and re-upgraded the firmware, just to make sure there was no issue there, and I'm currently running the latest version:
    Am I the only one facing this issue? Am I missing something in my config?
    Any help or suggestions would be greatly appreciated.
  • 2.  RE: IAP 315 / vc not showing mobile website
    Posted Sep 22, 2019 11:59 PM
    hi aardvark,
    The website your colleague is getting, was introduced to the IAP's with ArubaOS version 8.4. You are running on 8.3. I would recommend upgrading the IAP's to 8.5 if you really need this new GUI. If everything works well, stay with 8.3.
  • 3.  RE: IAP 315 / vc not showing mobile website
    Posted Sep 24, 2019 05:57 AM
    Ha! That makes complete sense. I'll go kick him until he tells me where he found the 8.5, since the support website doesn't go further than 8.3. Thanks a million!
