Okay. So, I am not using the 2nd port as an uplink port. I am using it to
connect a printer. My setup in the AP is I have 2 wireless ssid's. The
frost ssid is to let the network assign the vlan and ip addresses.
The 2nd SSID uses the VC to assign vlan and addresses.
When I create the wired profile for that port I use the same wired profile
as port 0 and port 1. These are network assigned vlan and addresses.
When I plug my laptop into port 1 I get an address from the network and the
correct mask and gateway and dns.
I cannot access the Internet or ping any of my internal lan addresses.
do I need a crossover cable?
Phil
