Frequent Contributor I
Re: IAP 93 versus IAP 105
@kdisc98 wrote:
Good tip - but be aware that the RAP109 deployment should be on table on shelf only (it's got plastic leg)
Sure, but first you can install it  wherever you want wth optional MNT. Second, you can use RAP-108 with ANT1/20 and ceiling monut.
Many regards,
Marek
Marek Krauze, CWNE# 174, ACMX #295, ACDX #356
Something cool, helpful or interesting in my post - click the Kudos Star.
Helped to solve your problem - Click Accept as Solution
