Hi All,
Just experienced weird problem with IAP207...
IAP207 will not be connected to internet at all and it's only bridge for wireless remote controlling of audio mixer. Only one vlan is involded and no dhcp or other services in this network.
I made normal initial Instant configuration via "SetMeUp..."-ssid (fixed ip address and one ssid) and made sure that I can control this single ap via ethernet also (works normaly) After configuration I tested control system for audio mixer also and everything worked fine.. At this point there was 12v external power supply to provide current to iap!
Then I made permanent cabling to iap using small unmanager PoE+ switch and after 10 minutes I noticed that System led was still blinking and Radio led was off... So I went back to 12v external power, booted iap and after about 2-3 minutes Radio led was on and iap was working.
After that I made connection to audio mixer by using ethernet cable and tried to reboot whole system. Again after about 10 minutes system was not ready and System led was blinking and Radio led was off. Then I tested to take off the ethernet cable from iap and after maybe 30-50 seconds Radio led went on and system starts to work just by taking of ethernet cable and put it back after less than one minute..
Any idea what could be the problem here?? IAP cannot be connected by using ethernet because it will not be initialized? Sorry about I don't have firmware version information give but iap is just bought so which ever version is now in currently shipped versions
