Highlighted
Occasional Contributor I
Re: Instant Mesh
Hi Jerrod
I followed the instructions and at the moment both IAP-387 are in proper mode
One as Mesh Portal and second as Mesh point.
Both have the same cluster name and keys.
However they don't see each other in RF link, even located in the same room one in front of other.
show ap mesh link and show ap mesh neighbour produce NULL output.
How can I debug radio communication?
Highlighted
Re: Instant Mesh
Hi aralelib,
I was in the same situation - I decided to follow a hunch and upgrade the firmware.  I started with the mesh point AP  - though the upgrade process was a hassle since I wasn't able to communicate with it via the eth0 port and IP I thought I had set.  I also didn't have DHCP server running at the outbuilding where I was deploying the mesh point AP and was lazy, not wanting to trot it back to the main site.  So I ended up factory resetting, allowing it to fully boot (takes a while and you want to let it finish, and then connecting to it using the default IP that results after it times out DHCP (in my case 169.254.207.166).  I was connected to another ethernet port on the same switch that I placed in the same isolated VLAN I intended to use for the standalone mesh.  I connected to the web GUI, logged in with admin/admin (though this took a while - the credentials will fail at first until fully booted). My only purpose in connecting to the web GUI was to ascent to the the country question (US in my case) and upgrade the firmware from the stock 8.4.0.0 to 8.5.0.2 (Hercules by the way). I'm sure I could have done it via TFTP, etc. but this was easiest for me. Note: there was no 'SetMeUp-<MAC>' SSID to connect to.  I don't believe the AP-387's do that, so wired connection was my only option (that I could see).
Anyway, the reason for this long narrative is that after the firmware update, I went through the procedure again as described by Jerrod....and voila, the mesh came right up.  Tagged my VLAN's at each end (untagged is my isolated mesh VLAN), and all good.  Interestinging, I did not upgrade the mesh portal AP, it is still running 8.4.0.0, no changes.  I probably will upgrade it, but my 'fix' only required upgrading the firmware on mesh point AP.
All I can surmise is that until location regulatory requirement is met, confirming country and/or loading current DRT file with the firmware update, the radios aren't activated?
A couple of small tweaks/additions to Jerrod's excellent directions:
I issued 'saveenv' after the initial setenv commands
On the Mesh Point only instructions, need to go into config mode:
conf t
wired-port-profile default_wired_port_profile
 trusted
 no shutdown
 type employee
exit
exit
....the second 'exit' gets you back to AP ENV  *then* you can issue:
enet0-bridging
commit apply
Highlighted
Re: Instant Mesh
Thanks a lot for reply.
It really helps.
Very strange, that Aruba deliver new product with outdated version 8.4.0.0 which has bugs and doesn't work out-of-the box.
Regards
Highlighted
MVP Expert
Re: Instant Mesh
It's not possible to keep all APs in inventory, distro, VADs and VARs on the latest code. When you default an AP (with the EXCEPTION of the 387) you have to make sure you create a VAP (2.4Ghz only, hidden is what I do), otherwise when the AP reboots, it defaults since it doesn't see a VAP, even if you created a mesh cluster or enabled mesh in the VC.
Country code is part of the initial setup as well, so without a VAP and it reboots, the radios are off until defined. It's a huge pain, but it's apparently something we cannot avoid.
Jerrod Howard
Distinguished Technologist, TME
Highlighted
Re: Instant Mesh
It really helps.
Regards
I don't think the manufacturer can upgrade code in a sealed box.
ArubaOS 8.5 User Guide
InstantOS 8.5 User Guide
Airheads Knowledgebase
Airheads Learning Videos
Remote Access Point Solution Guide
ArubaOS Consolidated Release Notes
ArubaOS 8 ViA VPN Solution Guide
Highlighted
Frequent Contributor II
Re: Instant Mesh
Is the unused VAP config still necessary in 8.5 and 8.6 code? I'm setting up a new standalone mesh, and my config didn't seem to be defaulting without one on an AP-377. I went ahead and added one anyway and now the mesh is up, just wondering if it's needed or can be removed.
Highlighted
MVP Expert
Re: Instant Mesh
I would personally create a VAP, I usually do a 2.4Ghz only, hidden, random SSID VAP. In cases where code upgrades later may change the default behavior, so having that VAP ensures the AP won't default.
Jerrod Howard
Highlighted
Re: Instant Mesh
Hello Guys
I have a question.
How many AP's support in Instant Mode?
Highlighted
MVP
Re: Instant Mesh
In an Instant mesh network, the maximum
  • Hop count is 2,
  • Number of mesh points per mesh portal is 8.
If a reply adequately addresses your issue, please click on the "Accept as Solution"
