Re: L2 Mobility in Instant AP (IAP) clusters
@DL8606 wrote:
Hi Joseph,
Yes. Client will be getting the same IP address. Same SSID.
Situation is we have 3 connected Block, block A -> C. Each Block has around 80 - 100 APs. 3 x VC in 3 different IP subnet. Client IP remains the same if they roam from Block A to Block B or C.
Is there any fine tuning can be done for this? Thanks
This is also my senario with 2 Block's we have 2 connected Block, block A B. Each Block has around 80 - 100 APs. 2 x VC in 2 different IP subnet same client vlan and the client vlan (/21 with broadcast filtering ) pass everywhere through trunk ports as they have common core switches.
Is there any document or suggestion if this is correct  and how can we have seamless L2 roaming ?
Thank you
Typically you would enable layer 3 mobility when roaming between two clusters:  https://www.arubanetworks.com/techdocs/Instant_423_WebHelp/InstantWebHelp.htm#UG_files/L3_mobility/Overview.htm?Highlight=layer%203
ArubaOS 8.4 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Airheads Learning Videos
Aruba Central Documentation
Sign up for Security Alerts
Aruba Technical Webinars
So we can not have the same client vlan with central DHCP server in 2 clusters ? We need to have different client and managment vlan per cluster ?
The problem is that firewall sessions are only synched between Instant APs in the same cluster.  If a client roams to a different cluster, even if that client is on the same layer 2 network, the firewall sessions are not synchronized.  It would be like the client's sessions are starting over.
You would have to configure layer 3 roaming between the two clusters for the firewall sessions to be synchronized.  I honestly have never done it where the layer 2 network is the same for both clusters.
If we dont want to use any firewall feature from the VC's as we have central firewall and all the policies and gateways are there  L2 mobility working ? Do you have any reference with that ?
Thank you.
I don't have any experience with that.  You should try to see if that makes a difference.
