Re: Resetting IAP 225 to defaults
You should type "show ap image version" to see what ArubaOS code it has.  It could be in the middle of upgrading.
ArubaOS 8.4 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Airheads Learning Videos
Aruba Central Documentation
Sign up for Security Alerts
Aruba Technical Webinars
Contributor I
It keeps going down...
(Aruba7210) #show ap image version ip-addr x.x.x.x
AP is down
Ken
Does "show log system 50" tell you why it is going up and down?
Contributor I
It has stayed up now. It has an IP address but still doesn’t show up on the controller.
Sent from my iPhone
How do you know what IP address it got?
Type "show datapath session table <IP address of AP> on the controller command line to see if it is sending any traffic to the controller.
If you do not see any traffic it might be time for the console cable...
Contributor I
Here is what I got.
(Aruba7210) #show datapath session table x.x.x.x
Q - Real-Time Quality analysis
E - Media Deep Inspect, G - media signal
r - Route Nexthop
A - Application Firewall Inspect
Source IP Destination IP Prot SPort DPort Cntr Prio ToS Age Destination TAge Packets Bytes Flags
x.x.12.109 y.y.11.6 17 8211 8222 0/0 0 0 0 0/0/5 9 0 0 FYCI
x.x..12.109 y.y.11.6 17 8211 8211 0/0 0 0 0 0/0/5 9 3 3367 FCI
y.y.11.6 x.x.12.109 17 8211 8211 0/0 0 0 1 0/0/5 9 0 0 FYI
y.y.11.6 x.x.12.109 17 8222 8211 0/0 0 0 1 0/0/5 9 1 134 FI
(Aruba7210) #
Ken
Okay.  I would type "show ap database" to see if the access point mac address has flags (the name of the AP would be the mac address).
I would also type "show log system all" to see if there are any references to that access point.
