Hello everyone,
I have the following case and would like some help from you.
Local network data:
IP Virtual Controller Instant: 192.168.0.25 255.255.252.0
Gateway: 192.168.1.254 255.255.252.0
DHCP: 192.168.1.50
VLAN: 1 Default
WLAN Network with DHCP itself, data:
SSID: EXTRA_LAN
IP - old Access Point: 192.168.30.1 255.255.255.0
DHCP Server internal range: 192.168.30.10 - 192.168.30.100
VLAN: 1 Default
* There is a rule in the organization's firewall that allows the 192.168.30.x network to go to the Internet.
Is it possible to create an SSID that makes DHCP Server as this example, without creating a new VLAN?
