WiFi Clients not getting IP Address - IAP 315 - Radius - VLAN
  • 1.  WiFi Clients not getting IP Address - IAP 315 - Radius - VLAN
    Posted Sep 13, 2019 05:18 AM
    Hi
    We are trying to set up an Aruba cluster using Windows NPS to authenticate. The clients are authenticating but are not receiving IP Addresses.
    Also our support here is a little strange, i have no real access to the NPS server as these are manged by our head office in another country, the config of the NPS has been checked with a working Aruba Cluster, the switches have been setup by an external company, although we can putty on to them and make changes.
    PS: When setting up the Aruba's initially (away from active network), i had two green lights, now when connected to live network i have an amber and green light.
    I have included network info below.
    Network Info
    Switch
    Cisco Stack 3750
    VLAN
    VLANID: 20 - Management
    Description: Infrastructure VLAN
    IP Address: 172.21.61.65 255.255.255.192
    VLANID: 63 - Wifi Clients
    IP Address: 172.21.63.1 255.255.255.0
    IP helper-address: 172.21.61.97 - DHCP
    IP helper-address: 172.21.61.93 - DNS
    VLANID: 40 - Wired Clients
    Description User Data VLAN
    IP address: 172.21.62.1 255.255.255.0
    IP helper-address: 172.21.61.98
    Port Information for Aruba IAP
    Interface: GigabitEthernet5/0/1
    Description: Wireless Access Point LAN-AP004
    Switchport access: vlan 20
    Switchport trunk allowed: vlan 20,63
    Switchport mode: access
    Power inline port priority: high
    Aruba Cluster
    Virtual Controller IP: 172.21.61.66
  • 2.  RE: WiFi Clients not getting IP Address - IAP 315 - Radius - VLAN
    MVP EXPERT
    Posted Sep 13, 2019 05:56 AM
    Your switch port needs to be a trunk port where the IAP is connected.
  • 3.  RE: WiFi Clients not getting IP Address - IAP 315 - Radius - VLAN
    Posted Sep 13, 2019 06:24 AM
    Hi Craig
    Thank you for your quick response. I will be on site next week and will update this post once configured.
    Kind regards
  • 4.  RE: WiFi Clients not getting IP Address - IAP 315 - Radius - VLAN
    Posted Sep 19, 2019 07:00 AM
    Hi Craig
    Sorry for late reply. I have changed the mode to trunk, however, now i am unable to access the IAP at all.
    Before changing to trunk we needed to change the encapsulation to dot1q.
    Kind regards
