last person joined: 11 hours ago
iPhone poor signal reported when 4 feet away from IAP
  • 1.  iPhone poor signal reported when 4 feet away from IAP
    Posted May 29, 2019 04:29 PM
    Hi my iPhone 7 running ios 12.3.1 has a really poor connection stats on Instant when i see it in the portal, its only 4 feet away
    Anyone any ideas?
  • 2.  RE: iPhone poor signal reported when 4 feet away from IAP
    MVP EXPERT
    Posted May 30, 2019 04:15 AM
    What model of IAP is this? What do you have configured for your RF settings? Is there any noise or interference within your environment? Do you see the same poor signal when testing with another device in the same location?
  • 3.  RE: iPhone poor signal reported when 4 feet away from IAP
    Posted May 30, 2019 04:46 AM
    Hi Craig
    Thanks for ur reply, i have 3 IAP-205H-RW in an instant cluster, i have attached the RF settings, other devices have sporadic connection/disconnection issues, my previous ISP wifi router didnt exhibit the same issues, i have wifi disabled on ISP router and im in a low interferance area, a small detached housing estate with 15m between houses
  • 4.  RE: iPhone poor signal reported when 4 feet away from IAP
    Posted May 30, 2019 04:47 AM
    where can i find any noise or interferance, is there a tab i can screenshot for u?
  • 5.  RE: iPhone poor signal reported when 4 feet away from IAP
    MVP EXPERT
    Posted May 30, 2019 05:12 AM
    It is located under the RF part of the Dashboard. Please also ensure you review the antenna pattern of the 205H to ensure the APs are correctly placed.
    https://www.arubanetworks.com/assets/ds/DS_AP205H.pdf
    What is the current ARM power levels set on your AP? Can you provide the output of "#show aps"
