Ok, have a pair of IAP515s meant to be deployed in a tiny storefront using home style cable internet and a very small POE+, managable switch. Some conditions, with questions to follow;
A - isp modem only provides 1 dhcp address to 1 mac address at a time)
B - I can run new wires as needed and the gear is reasonably close so that's not a huge issue;
c - all clients are wireless, so there's no need to provide drops to anything other than the APs
d - there's no requirements restricting where addresses come from or range (the switch can have a dedicated subnet between it and the modem, between it and the APs, and the APs can give out addresses to clients, or any combination as long as you repect A) as long as everyone can reach the internet.
1 - Is it true that the 515 series needs both eth ports hooked up to POE+ for full operation (the same way older 2xx and 3xx units needed POE+ over POE or they would be in low power mode)?
2 - how would you recommend getting the APs both to see each other and the internet (vlan eth0 on the vc and the modem uplink at the switch? let the switch do dhcp between itself and the modem? tag both eth0 ports on both APs to the modem vlan?
3 - would there be a way for the APs to be redundant as the vc and share internet access so they can swap roles (using tags or creative vlan slicing)?
I can't tell if this is a simple issue I'm overthinking, or a real tough one I'm too simple to wrap myself around (using home grade stuff sometimes is more of a pain than enterprise grade!)
Any input would be appreciated, thx!
