Q:
What commands can we execute from limited CLI access
We can login as ampadmin user and select option "11" which is for enter commands,
AirWave Management Platform 8.2.6 on localhost.localdomain 1 Upload File 2 Download File 3 Delete File 4 Backup 5 Restore 6 Support 7 Upgrade 8 Advanced 9 Security 10 Custom Commands 11 Enter Commands q >> Quit Your choice: 11
Running Enter Commands
Type 'help' for the list of commands. $
Once we are in that prompt we can run the command "service". This will list all the services and its status.
Your choice: 11
Type 'help' for the list of commands. $ service auditd: auditd (pid 30145) is running... awrrdtool: crond: crond (pid 29936) is running... docker: docker is stopped httpd: httpd______________________________________ (pid 30783 2004 2001 1998 1993 1990 1987 1984 1981 1978 1975 1972 1969 1966 1963 1960 1957 1954 1924 1919 1916 1912 1906 1886 1880 1876 1871 1870 1869 1868 1867 1866 1864 1661) is running... iptables: running network: Configured devices: lo eth0 Currently active devices: lo eth0 docker0 nginx: nginx (pid 1735) is running... ntpd: ntpd (pid 1939) is running... postfix: master (pid 30036) is running... postgresql: postmaster (pid 31627) is running... rabbitmq-server: beam.smp (pid 32522) is running... radiusd: radiusd is stopped redis: redis-server (pid 1899) is running... redis-vrf: redis-server is stopped rrdcached: rrdcached (pid 30688) is running... sshd: openssh-daemon (pid 1061) is running... support_connection: support_connection.pl is stopped vmtoolsd: vmtoolsd (pid 30570) is running...
From here incase you want to start or stop a service we can use the command "service <name of the service from above output> start/stop/restart" For example if i want to restart the vmtool service, i will be using the below command $ service vmtoolsd restart Stopping vmtoolsd: [ OK ] Starting vmtoolsd: [ OK ]
Couple of other commands which we can run are below, To watch the daemons
# wd To see the running process and memory/cpu consumed # top To see the memory # free -g To see IP details # ifconfig
