Q:
How to install VMware tools on Airwave 8.2.6 & above version?
We have added open-vm-tools package from 8.2.6 code. If you are planning to install 8.2.6 or newer version, it will automatically install and service will start running. We can check the status by running command from AMPCLI
AirWave Management Platform 8.2.6 on localhost.localdomain 1 Upload File 2 Download File 3 Delete File 4 Backup 5 Restore 6 Support 7 Upgrade 8 Advanced 9 Security 10 Custom Commands 11 Enter Commands q >> Quit Your choice: 11
Running Enter Commands
Type 'help' for the list of commands. $ service auditd: auditd (pid 1207) is running... awrrdtool: crond: crond (pid 1702) is running... docker: docker dead but subsys locked httpd: httpd______________________________________ (pid 30556 20005 20002 19999 19975 19972 19969 19959 19770 19730 19672 19627 19622 19610 19600 19591 19558 19546 19533 19529 19526 19523 19518 19509 19492 19486 19473 19467 19455 19451 19448 19431 19428 19418 19203 18940 10811 10592 9088 6711 6707 6669 4185 426 422) is running... iptables: not running network: Configured devices: lo eth0 eth1 Currently active devices: lo eth0 nginx: nginx (pid 19232) is running... ntpd: ntpd is stopped postfix: master (pid 1599) is running... postgresql: postmaster (pid 1488) is running... rabbitmq-server: beam.smp (pid 2263) is running... radiusd: radiusd dead but subsys locked redis: redis-server (pid 2251) is running... redis-vrf: redis-server is stopped rrdcached: rrdcached (pid 13434) is running... sshd: openssh-daemon (pid 1419) is running... support_connection: support_connection.pl is stopped vmtoolsd: vmtoolsd: (pid 14123) is running
Note: If we install it on Hyper-V, the system installs the rpm package but doesn't’start the service, if it detects it is a pure hardware installation (non-VM). In service list we will see it is not running with ”dead, but pid file exist” message.
