Does the resources are set to shared or reserved for this instance in VM host machine? It is all ways recommand to reserve the resources to Airwave instance and allocated CPU cores are physical not Hyper-Thread.
If allocated cores are hyper thread increase more and also need to allocate 20% more resource for Airwave server installed on VM envoirment.
If large number of syslog&traps coming to Airwave in system>syslog&trap page try disable unwanted traps on controller and also change syslog logging level if it set to debug!
