Network Management
Airwave CLI commands.
  • 1.  Airwave CLI commands.
    Posted Sep 19, 2018 06:04 AM
    Hi team
    Airwave.
    Please keep adding the commands as per your knowledge.As I am new to Aruba airwave and am learning the CLI .please help me out by sharing the CLI commands .
  • 2.  RE: Airwave CLI commands.
    Posted Sep 19, 2018 07:43 AM
    Airwave CLI is blocked from versin 8.2.5
  • 3.  RE: Airwave CLI commands.
    Posted Sep 19, 2018 07:49 AM
    Any way to obtain it.
  • 4.  RE: Airwave CLI commands.
    Posted Sep 19, 2018 07:51 AM
    Contact Aruba TAC,Only TAC can login to root level.They can help you
  • 5.  RE: Airwave CLI commands.
    Posted Sep 19, 2018 08:12 AM
    I had the root access.i just want to know full command sets...Like free-g chkcrond like that.
  • 6.  RE: Airwave CLI commands.
    Posted Sep 19, 2018 08:28 AM
    Which Airwave version you are using..???
  • 7.  RE: Airwave CLI commands.
    Posted Sep 19, 2018 08:31 AM
    I am using 8.2.6 version
  • 8.  RE: Airwave CLI commands.
    Posted Sep 19, 2018 10:40 AM
    If you're in the AMPCLI menu, under Enter Commands, the 'help' cmd should output a list of options.
    If you're root'd in, there's some stuff in the bashrc, but be aware that they might go away or change in future releases since we don't expect/advocate usage of the direct root shell.  If you find an operation that you can only do from root shell and not from the AMPCLI menu, then please let us know so that we can generate the proper tracking for future feature enhancement.
  • 9.  RE: Airwave CLI commands.
    Posted Sep 19, 2018 10:46 AM
    Hi Rob,
    Thanks for the reply.
    We are using root only for troubleshooting the advanced issues.
    Like logs send by airwave.
    Memory clearance.
    Core usuage.
    That is why I want commands like
    #free -g
    #vi logs etc
    That root CLI commands actually are needed.
    Will appreciate your help.
  • 10.  RE: Airwave CLI commands.
    Posted Sep 19, 2018 11:29 AM
    Those cmds are general Unix cmds.  You can find out more about them from any Unix source like these:
    https://linux.die.net/man/
    https://www.kernel.org/doc/man-pages/
    http://cheatsheetworld.com/programming/unix-linux-cheat-sheet/
    Cmds like top, snmpwalk, etc are all part of public libraries.  I was expecting the question to be more along the lines of AirWave unique cmds like amp_backup or amp_restore (both of which happen to be available from AMPCLI).
