Im having a little problem and i have some questions.
im new to Aruba equipment in my new job(First Day) they have a Aruba controller and AP´s and some standalone Cisco AP´s a they told me that they are buying Aruba Airwave and i wanted to know some things:
-The integration between the Controller and Ariwave is via SNMP? from what i have investigated it seams like that.
-Can i make changes to the Cisco AP from Airwave and what changes can i make? from what i have read i cand define some parameters for the antena , ip address, etc.
-Can i define 802.1x for the SSID from Airwave (to Aruba AP´s dependents of the controller and to the Cisco AP´s) or it this needed to do from the controller and directly to the Cisco AP´s too?
-Do you have any recomandations when using 802.1x
Thanks for the help.
Greetings,
Gerardo Andree Mejía
