Network Management
last person joined: 3 hours ago
Airwave passsword recovery
This thread has been viewed 22 times
  • 1.  Airwave passsword recovery
    Posted Nov 14, 2018 09:11 AM
    Hello Airheads,
    I have access to the web console but no console access (don't have the password).
    I've found this steps:
    https://community.arubanetworks.com/t5/Network-Management/Tutorial-Airwave-Root-password-recovery-Jan14-Tutorial/m-p/307190#M7605
    However, as per attached screenshot, no way to edit de boot menu.
    What's the best approach to solve that?
  • 2.  RE: Airwave passsword recovery
    Posted Nov 14, 2018 10:04 AM
    You should open a TAC case, I had the same problem and it was solved quickly by a HPE engineer.
  • 3.  RE: Airwave passsword recovery
    Posted Nov 14, 2018 01:04 PM
    it'd help to know what version of AirWave you have running.  Anything before 8.2.4 would require booting to single user mode.
    From 8.2.4-8.2.6.1, there's the amprecovery user that could be used to reset ampadmin pw.  Password is 'recovery'.  This amprecovery account is only accessible from console (not remote ssh).
    8.2.7 and newer -> fresh installs allowed choosing a different name other than amprecovery.  And the ampadmin is able to reset the amprecovery password - otherwise it's the default 'recovery'.
  • 4.  RE: Airwave passsword recovery
    Posted Nov 14, 2018 04:48 PM
    It did the trick, thanks.
    However I've found this screen. No way to change the password.
  • 5.  RE: Airwave passsword recovery
    Posted Nov 14, 2018 05:27 PM
    Ah yes - so the steps to reset for security purposes was made more difficult.  Letting users reset the password was a security risk since anyone could walk into a server lab and console access.
    So step 1 will generate the new key, step 2 will scp that key so that you don't have to type it all, step 3 is activating the key.  Emailing the hash to TAC is the only way to get the translation since it's encrypted with gpg keys.
    Then once you activate -> login w/ the ampadmin user, go to Security -> Reset OS pw to change the pw to something easier (but still secure).
  • 6.  RE: Airwave passsword recovery
    Posted Nov 19, 2018 08:43 AM
    I have access to the Web Console. Is there any way to reset the console access from it?
    If not, do I need to have an active support contract to reset the password?
    Thanks again.
  • 7.  RE: Airwave passsword recovery
    Posted Nov 19, 2018 09:34 AM
    No, the CLI can only be reset from CLI.  As for support, I'm not completely sure. but I'd guess you'd need an active support contract - you'd have to try opening a case to find out.
