I've configured a batch of switches to reboot every 3 months on the second Saturday of that month but it simply won't reboot.
All switches are in Monitoring + Firmware updates only but I have enabled the "Allow Rebooting Monitor Only APs/Devices" setting under Firmware upgrade/reboot option.
Setting the Desired Start Date option for a time before or on the date I want it to restart (2nd saturday every 3 months at 3am) doesn't seem to do anything either as the switches simply won't reboot.
If I set the Change Job to occur One Time and set a specific date and time, it does reboot just fine. I changed it to the third Saturday of the month to test it and it didn't do it. Now I changed it to the forth but I'm not confident it will do either.
We are running Airwave 8.2.6
What could I be missing here?
