Network Management
Highlighted
MVP Expert
Re: HPE switches and AIrwave
Hi ,
Try add it as HPE switch, in drop down list we have option to select as HPE.
Pavan
Pavan Arshewar | ACCP
If my post address your queries, give kudos and accept as solution!
NOTE: Answers and views expressed by me on this forum are my own and not necessarily the position of Aruba or Hewlett Packard Enterprise.
Highlighted
Frequent Contributor I
Hello!
I would like to ask a related question. I am running AMP 8.2.7 and I want to manage an Aruba 2930F switch with WC.16.05.0007 version. I have set the following command on the switch (like the first person said):
amp-server ip <AMP server IP address> group aruba_switches folder aruba_switches secret secret
Then I added the switch manually under Device setup->add. I added it as Aruba device. Then I set the IP adress of the switch and the host name. In the community string I typed the "secret".
Then my switch comes up in down state, and has a "Status: Down (SNMP get failed) ".
Also getting the following log in the switch:
I 08/31/18 13:13:46 05103 amp-server: Default, Primary or Management VLAN is not configured with IP or DHCP.
W 08/31/18 13:13:38 00236 snmp: Security access violation from <AMP server IP address> for the community name or user name : secret (8 times in 60 seconds)
What am I missing?
I also tried to create snmpv3 user and setting that in the "manage" tab, but with no luck.
The only way I could get the switch to communicate with AMP is when I do a ZTP with Activate. Then the switch comes up to AMP, but when I change the IP adress to static (because it has a DHCP IP because of the ZTP) then the switch stops communicating and gives me a Status: Down (SNMP get failed) message again.
If someone has any idea please share.
Daniel
Highlighted
And on more thing, if I add it as custom device, it immediately comes up as "UP" in AMP.
So I am thinking it is not coming up because a wrong device selection, but I didn't find any "aruba switch" selection when I add it manually. I also tried adding it as HPE type switch but failed.
Daniel
Highlighted
Moderator
I see you're trying to do SNMPv3 -> make sure the Group - select group - Basic tab is set to use SNMPv3 to communicate with the device.
Also, make use of this guide for testing SNMP communication
Rob Gin
Senior QA Engineer - Network Services
Aruba Networks, a Hewlett Packard Enterprise Company
Highlighted
Did you by any chance try the following command (on the switch):
snmp-server response-source dst-ip-of-request
Better late than never!
Kindly share the solution if you have already found it!
Highlighted
For me, to solved the "Default, Primary or Management VLAN is not configured with IP or DHCP." problem. I had to change my primary vlan from the default of 1 to 253 because we use 253 for our switch management IP. The command was: primary-vlan 253
Then the debug ztp output showed:
0000:00:38:57.68 ZTP mairwaveCtrl:Received message 0x910001
0000:00:38:57.68 ZTP mairwaveCtrl:Default, Primary or Management VLAN is configured with IP or DHCP
0000:00:38:57.68 ZTP mairwaveCtrl:AMP server registration started.
0000:00:38:57.68 ZTP mairwaveCtrl:IPSEC ZTP: No amp type vpn, Check-in to Airwave
0000:00:38:57.68 ZTP mairwaveCtrl:sending request to  https://192.168.10.167/switch_https
0000:00:38:57.68 ZTP mairwaveCtrl:Added X-Type: Device-Reg
0000:00:38:57.68 ZTP mairwaveCtrl:Added X-OEM: HP
0000:00:38:57.68 ZTP mairwaveCtrl:Added X-Mode: SWITCH
0000:00:38:57.68 ZTP mairwaveCtrl:Added X-Current-Version: WC.16.09.0004_786
0000:00:38:57.68 ZTP mairwaveCtrl:Added X-Device-Info: TW94HKZ2LL,
38:21:C7:BA:5C:F0, 2930F-8G-PoE+-2SFP+ Switch
0000:00:38:57.68 ZTP mairwaveCtrl:Added X-Group: Kitchener
0000:00:38:57.68 ZTP mairwaveCtrl:Added X-Folder: Kitchener
0000:00:38:57.68 ZTP mairwaveCtrl:Added X-Shared-Secret: d2l-kit-switches
0000:00:38:57.68 ZTP mairwaveCtrl:Added X-Device-State: Non-factory
0000:00:38:59.53 ZTP mairwaveCtrl:Switch registered Sucessfully 0 - HTTP/1.1 200 OK
Cheers, Mark W.
