Hi
Can anyone tell me why although my two controllers hostnames are different that Airwave picks them up and gives them the same hostname?
(BFS-AH-WLAN-1) #show hostname
Hostname is BFS-AH-WLAN-1
(BFS-AH-WLAN-2) #show hostname
Hostname is BFS-AH-WLAN-2
When you click into each one the serial info is unique and correct but the display name shows duplicate hostname:
This has happened on another site as well.
