I've never had any issues with changing the channel width. That being said, within the User Guide certain AP models (200 Series, AP-205H, 210 Series, 220 Series, 270 Series and 320 Series access points) will trigger a radio restart if the 40/80 channels are modified under the High-throughput SSID Profile.
Play it safe and do it out of hours
