I am trying to install Aruba Airewave on REDHat Linux 8.1 and getting the below error message:
I followed the below instruction to setup Airwav.
https://community.arubanetworks.com/t5/Monitoring-Management-Location/Install-AirWave-8-0-on-RedHat-RHEL/ta-p/215001
amp-install.log contains :
Does anyone know how to fix this issue ?
Thanks in advance.
Installing Airwave on RHEL is no longer supported. You should use the ISO to install the OS with Airwave together (for bare metal server) or the OVA (for VMWare).
Thanks Herman,
I appreciate your help.
