Do you have static IP assignment on the other vlans than VLAN1?
When in one of the VLANs, can you ping the switch IP for the same VLAN?
Can you ping a switch IP in another VLAN?
Do you see the ARP entries in the switch for your clients? Do you see the ARP entries for the switch IP in your client?
If your default gateways are not the switch IP addresses, do you have a route back from your routers/gateways for the IP addresses you assigned to the VLANs pointing to your switch?
Probably easiest to find someone to troubleshoot together, like your reseller/partner, or Aruba Support.
