Hello all;
This weekend I swapped out my MDF old 8212zl switch for a newer 5412r. Most of it went smoothly, but I am having major problems between VLANs. I cannot consistenly reach or ping one side of the network to another on VLAN-10. I have not changed the configuration on any of my IDF switches, and copied the config from the 8212zl onto the 5412r.
From MDF 5412r to client:
mdf-hp5412r# ping 10.17.10.243
10.17.10.243 is alive, time = 1 ms
Request timed out.
Request timed out.
Client to client:
Request timed out.
Request timed out.
Request timed out.
Reply from 10.17.10.243: bytes=32 time<1ms TTL=63
Request timed out.
IDF Switch to client (switch that client is directly connected to):
do-hp-e3500yl-0# ping 10.17.0.243
Request timed out.
Request timed out.
Request timed out.
Request timed out.
MDF Config
Running configuration:
; J9851A Configuration Editor; Created on release #KB.16.10.0009
; Ver #14:6f.6f.f8.1d.fb.7f.bf.bb.ff.7c.59.fc.7b.ff.ff.fc.ff.ff.3f.ef:00
hostname "mdf-hp5412r"
module A type j9993a
module B type j9988a
module C type j9989a
module D type j9988a
module E type j9995a
module F type j9538a
module I type j9986a
module J type j9990a
module K type j9986a
module L type j9986a
trunk A5-A6 trk5 lacp
trunk B17-B18 trk25 trunk
trunk C17-C24 trk49 trunk
trunk L11-L12 trk132 lacp
timesync sntp
sntp unicast
sntp server priority 1 132.163.97.4
sntp server priority 2 129.6.15.27
time daylight-time-rule continental-us-and-canada
time timezone -8
ip timep dhcp
ip route 0.0.0.0 0.0.0.0 10.17.50.2
ip routing
ip multicast-routing
oobm
ip address dhcp-bootp
ipv6 enable
ipv6 address dhcp full
exit
vlan 1
name "DATA_MGMT"
no untagged D1-D2,E1,I1-I24,J1-J24,K1-K24,L1-L6,L8-L10,L13-L24,Trk132
untagged A1-A4,A7-A8,B1-B16,B19-B24,C1-C16,D3-D24,E2-E8,F1-F8,L7,Trk5,Trk25,Trk49
ip address 10.17.0.230 255.255.255.0
ip helper-address 10.17.0.50
ipv6 enable
exit
vlan 10
name "USERS"
untagged
I1,I5-I6,I8-I10,I12-I20,I22-I24,J2-J3,J5-J8,J10-J11,J13-J14,J16,J18-J19,J21-J24,K1-K4,K6,K8-K9,K11-K24,L1-L6,L8-L10,L13
-L24
tagged A1-A4,A7-A8,B1-B16,B19-B24,D3-D24,E2-E8,F1-F7,I2,I11,I21,J4,J12,J15,J20,K5,K10,L7,Trk25
ip address 10.17.10.1 255.255.255.0
exit
vlan 20
name "AP"
untagged E1,I3-I4,I7,J1,J9,J17,K7,Trk132
tagged A1-A4,A7-A8,B1-B16,B19-B24,D3-D24,E2-E8,F1-F7,L7,Trk25,Trk49
ip address 10.17.64.1 255.255.224.0
exit
vlan 30
name "APPLE_TV"
ip address 10.17.30.1 255.255.255.0
exit
vlan 40
name "VoIP"
ip address 10.17.40.1 255.255.255.0
qos priority 6
voice
exit
vlan 50
name "GATEWAY"
untagged D1-D2
ip address 10.17.50.1 255.255.255.0
exit
vlan 60
name "Wifi Management"
tagged B1-B16,B19-B24,D3-D24,E2-E8,F1-F7,Trk25,Trk49,Trk132
ip address 10.17.6.1 255.255.255.0
exit
vlan 61
name "Wifi Infrastructure"
ip address 10.17.161.1 255.255.255.0
exit
vlan 62
name "Wifi Staff"
ip address 10.17.162.1 255.255.255.0
exit
vlan 63
name "Wifi Student"
ip address 10.17.176.1 255.255.240.0
exit
vlan 64
name "Wifi Guest"
ip address 10.17.208.1 255.255.248.0
exit
vlan 100
name "PUBLIC"
tagged A1-A4,A7-A8,E2-E8,F1-F7,L7,Trk25,Trk49
ip address 206.78.76.1 255.255.255.0
exit
vlan 200
name "IPS"
tagged A1-A4,A7-A8,B1-B16,B19-B24,C1-C12,D3-D24,E2-E8,F1-F8,L7,Trk25
ip address 10.17.207.1 255.255.255.0
exit
spanning-tree
spanning-tree Trk5 priority 4
spanning-tree Trk25 priority 4
spanning-tree Trk49 priority 4
spanning-tree Trk132 priority 4
no spanning-tree bpdu-throttle
spanning-tree force-version stp-compatible
no tftp server
no autorun
no dhcp config-file-update
no dhcp image-file-update
IDF Config
; J8693A Configuration Editor; Created on release #K.15.06.0017
; Ver #02:10.0d:1f
hostname "do-hp-e3500yl-0"
time timezone -8
time daylight-time-rule Continental-US-and-Canada
module 1 type J86yyA
module 2 type J86xxA
interface 48
name "TRUNK"
exit
trunk 47-48 Trk47 Trunk
ip default-gateway 10.17.0.230
vlan 1
name "DATA_MGMT"
untagged 33-34,37-46,Trk47
ip address 10.17.0.240 255.255.255.0
no untagged 1-32,35-36
exit
vlan 10
name "USERS"
untagged 2-4,6,10,13-17,20,22,24-28,31-32
tagged 1,5,8-9,11-12,19,21,23,45-46,Trk47
no ip address
exit
vlan 20
name "AP"
untagged 18,29-30,35-36
tagged 45-46,Trk47
no ip address
exit
vlan 30
name "APPLE_TV"
tagged 45-46,Trk47
no ip address
exit
vlan 40
name "VoIP"
untagged 7
qos priority 6
tagged 1-6,8-17,19-28,31-32,45-46,Trk47
voice
no ip address
exit
vlan 50
name "GATEWAY"
tagged 45-46
no ip address
exit
vlan 100
name "PUBLIC"
tagged 45-46,Trk47
no ip address
exit
vlan 60
ip helper-address 10.17.0.12
tagged Trk47
no ip address
exit
vlan 61
tagged Trk47
no ip address
exit
vlan 62
name "Wifi Staff"
tagged Trk47
no ip address
exit
vlan 63
name "Wifi Student"
tagged Trk47
no ip address
exit
vlan 64
name "Wifi Guest"
tagged Trk47
no ip address
exit
vlan 200
name "IPS"
tagged Trk47
no ip address
exit
fault-finder bad-driver sensitivity high
fault-finder bad-transceiver sensitivity high
fault-finder bad-cable sensitivity high
fault-finder too-long-cable sensitivity high
fault-finder over-bandwidth sensitivity high
fault-finder broadcast-storm sensitivity high
fault-finder loss-of-link sensitivity high
fault-finder duplex-mismatch-hdx sensitivity high
fault-finder duplex-mismatch-fdx sensitivity high
fault-finder link-flap sensitivity high
sntp server priority 1 10.17.0.248
spanning-tree
spanning-tree Trk47 priority 4
no autorun
password manager
password operator
If the solution is obvious, then I've been awake waaaayyyyy too long!
