Network Management
Highlighted
Re: Reconcile Airwaves to WLC
Currently Airwave do not have an automatic option to delete down AP's from UI. If this is one time activity, I would suggest to use bulk delete. However, Airwave has a script delete_aps.pl which can be run in CLI to delete down AP's. This can be added to cron job to rundaily/weekly (or any periodic interval). For this TAC has to log into the shell and execute the script and/or make the script as cron job.
And, ofcourse, when the AP's show up or new AP's added, Airwave will show the the devices under 'New Devices' tab unless a group and folder was set in Automatic authorization section of AMP Setup > General > Automatic Authorization.
View solution in original post
