Hi.
I installed an AMP server to manage two IAP cluster. I configured the first VC with SNMP community and Airwave options. It appeared at airwave and then I moved to the correct folder and group.
The APs are showing 'Good', but the VC is showing 'Mismatched'.
I tried:
- Remove and insert again
- Fetch the VC template from the VC
- Delete the VC template
- Move the VC to a different group of the IAPs.
None had worked.
Someone knows how to fix this?
AMP Version: 8.2.8.1
