Network Management
Highlighted
Occasional Contributor I
Re: What triggers are best to monitor in Airwave
Thanks Vishnu...
Will implement and see the effect...
Keep you posted...
Highlighted
Thanks Dude!!! It's working fine.
Highlighted
Can you please let me know if we can configure Radius authentication on CPPM for login and snmp string?
Regards
Gaurav pandey
Highlighted
Moderator
You can setup AMP to authenticate off of CPPM over RADIUS, but SNMP does not tunnel through CPPM.
The short:
In AMP configure CPPM as auth destination
AMP Setup -> Authentication -> RADIUS
In CPPM configure policy to assign role with Radius:Aruba Type:Aruba-Admin-Role (4)
SNMP communication between AMP and CPPM is solely for AMP to collect some CPPM server stats over SNMP.  There's several feature requests for adding further integration in the ideas portal to upvote.
Rob Gin
Senior QA Engineer - Network Services
Aruba Networks, a Hewlett Packard Enterprise Company
