Attempting to simulate some future ZTP work in GNS3 with the ArubaOS-CXSimulationSoftware10.04.0001-1. By default, it looks like a switch would have it's mgmt port configure for ip dhcp. However, this virtual O/S comes with all ports administratively down. So at a minimum, I need to adjust the config to up one of the interfaces and save it. After I reboot it, it looks like DHCP and ZTP starts to work, because it grabs the configuration file but then logs this Status : Aborted - Custom startup configuration detected:
2020-05-29T16:05:17.198401+00:00 switch dhcp_options[9970]: Event|8718|LOG_INFO|AMM|-|ZTP: Received TFTP server 192.168.0.2 from dhcp server
2020-05-29T16:05:17.198949+00:00 switch dhcp_options[9970]: Event|8720|LOG_INFO|AMM|-|ZTP: Received config file ./tftpboot/base.cfg from dhcp server
switch#
switch# show ztp
information Information about ZTP
switch# show ztp information
TFTP Server : NA
Image File : NA
Configuration File : NA
It could be that I just can't simulate this due to the way the virtual O/S works? Assume ZTP stops if it detects any configuration in any form and that is why it doesn't work?
