Network Management
how to add port to vlan on AirWave ?
  • 1.  how to add port to vlan on AirWave ?
    Posted Dec 11, 2019 07:14 AM
    Hi All
    how (if i can.. ) i add port to vlan on airwave version 8.2.9.1?
    Br Avi
  • 2.  RE: how to add port to vlan on AirWave ?
    Posted Dec 11, 2019 12:23 PM
    Can you please elaborate on the query and use case. Airwave has one port for management and Data. Even with Ethernet bonding, the interface to Airwave is only one. So, it depends on what port (eth0-eth3) you have connected and to which VLAN for Airwave to communicate to all Network devices.
  • 3.  RE: how to add port to vlan on AirWave ?
    Posted Dec 12, 2019 06:10 AM
    Hi
    what i mean is i have switch managed on the airwave and i want
    to add port from the switch to vlan via airwave .
    can i do that ?
  • 4.  RE: how to add port to vlan on AirWave ?
    Posted Dec 12, 2019 12:39 PM
    Is it an Aruba switch? If so, using config snippets to add a port to VLAN is possible. It is detailed in Airwave switch config guide on the support site.
