Highlighted
Re: Ssid not broadcasting
Nope. noauthapgroup is the name of of the policy. Remove it.
ArubaOS 8.5 User Guide
InstantOS 8.5 User Guide
Airheads Knowledgebase
Airheads Learning Videos
Remote Access Point Solution Guide
ArubaOS Consolidated Release Notes
ArubaOS 8 ViA VPN Solution Guide
Highlighted
tnx mate! you saved my weekend :)
Cheers,
Nikola
Highlighted
Contributor II
yes i fix the issue i made this procedure.
Take the RAP and configured in diferente gruop and it works i roll back the AP to the group it belong and doesnt work so i erase the gruop and create again and works, i dont know what was the problem but now is running very well.
