6.6.9 > 6.7/8 another question!
  • 1.  6.6.9 > 6.7/8 another question!
    Posted Apr 12, 2019 06:12 AM
    Hey
    I was preparing to upgrade to 6.7 from 6.6.9 (hyper v VM cluster) and now I see that 6.8 is just coming out!
    I presume if I patch to 6.6.10 I would see 6.8 as an download option in software updates.
    Recommended to go straight to 6.8 and skip 6.7 now?
    PS
    Does 6.7/8 require:
    aaa accounting network start-stop radius
    or would
    aaa accounting network stop-only radius
    be OK?
  • 2.  RE: 6.6.9 > 6.7/8 another question!
    Posted Apr 12, 2019 07:31 AM
    It's the first 6.8 release. Do question is, do you dare?
    I will advise to stick to 6.7. At least until the first patch for 6.8
  • 3.  RE: 6.6.9 > 6.7/8 another question!
    Posted Apr 12, 2019 12:49 PM
    Hello, you can upgrade to either, that should not be a problem, However, i would recommend you to go through the release notes for the known issues etc. Accounting and authentication should be seamless after the upgrade.
