How are you testing on your Windows10 client?
Machine authentication only takes place at specific times (logon, logoff and boot up (if single signon is enabled)).
If you have the client configured to use Windows credentials, you won't be prompted for any username/password.
Ensure your 802.1x configuration on the client is correct and then logoff and logon.
