Good Morning all
We are int the end fase of implementing a wireless network.
Now is time for guest..
we have AOS8 cluster installed and Clearpass version 6.8 ( cluster)
We configured the guest wlan on th MC node and create the guest authentication with mac on Clearpass.
The DHCp is on the client side and the default GW is a CHeckpoint Firewall
We are not getting captive portal , and checking the FW logs we see that is address spoofing.
As I understand when we are connected to the guest , we get IP address but we are not redirected to the portal. on the chekpoint I only see drops from my client IP address ( IOS device for example)
IS there anything that could be done on the Aruba solution or we should config the FW to permit the client to come inside again on traffic.
Hope I cloud explain it good for understanting.
Regards
