We have an issue with the Aruba VIA client. We run our clients in split-tunnel and, as you know, when a DNS request is made, the DNS request is sent to both the public and Corporate DNS servers. If both DNS servers return a valid IP address, the machine always chooses the public DNS IP. We found out today that this is because the Aruba VIA client sets the interface metric to 500 which makes it basically the least-preferred interface on the machine. In our experience, this is opposite behavior of other major vendors like Pulse Secure. We can manually change the metric while the interface is connected and it works correctly, but after disconnecting and reconnecting, the interface is reset back to 500. Does anyone know of a way to change this behavior? I can probably rig up a login script to change it, but this may prove to be problematic for our users installing this client on their home computers. Thanks in advance for any suggestions you may have.
