Hi All!
What do I need to configure and check to be sure CPPM takes into account CRL while doing EAP-TLS? I see CRL distribution point URL in the certificate issued by ADCS and I have added CRL link to Clearpass Administration-> Certificates -> Revocation Lists. The last one is successfully downloaded as I see in logs. Anything else? Do I need to modify the default EAP-TLS auth method?
Thank you.
