I have a public guest network, that uses a controller based captive portal for acces. The IP addresses that the guest network use is totally seperate from my production wirless, however the IP address captive portal is hosted on by default is the management IP address of the controller. Therefore I have to allow access from my Guest network to my controller which I prefer not to do.
I have assigned an IP address to my guest network vlan, and would like to have the captive portal accessed via this IP address instead of the management IP address as the guest network will have access to itself already.
Is it possible, and if so how can i change which IP address my guest network captive portal is hosted on?
