Let me start out with I do have an active TAC case open with Aruba currently. But, I am fishing to see if anyone out here is or has experienced the same type of problem.
Our cluster consists of 8 (25k) nodes of which two are configured as profilers. We have roughly 250k objects in our endpoints DB and the systems appear to be keeping up fine.
The problem is in the service, we have Profiling enabled and finished with an Aruba Port Bounce once profiling is completed. This is taking roughly 5 minutes for the profiling to complete - part of the problem. SEcond part of the problem is that some devices such as printers, security devices, environmentals etc. don't respond to a second AUTH request once the port has bounced because the device has an IP and is on the network.
So two problems - one is profiling performace and the second is non-intelligent compute devices ignore a second AUTH. What can be done to improve profiling performance and what are others doing for devices that need Corporate network access but are incapable of 802.1x?
Thank you for any input.
