Clearpass Rollback RPM package and upgrading to v6.8.1
  • 1.  Clearpass Rollback RPM package and upgrading to v6.8.1
    Posted Jul 03, 2019 03:06 AM
    Our Clearpass servers are currently running 6.8.0 and there are two new patches available:
    Patch ClearPass Policy Manager Cumulative Patch 1 for 6.8.0* 6.8.1.109777
    Patch ClearPass 6.8.0 Rollback RPM Package
    The documentation isn't clear as to whether the Rollback package is required to be installed before installing the patch/upgrade to 6.8.1 or if it's only required to undo the 6.8.1 patch upgrade should there be a problem?
  • 2.  RE: Clearpass Rollback RPM package and upgrading to v6.8.1
    Posted Jul 03, 2019 03:11 AM
    It’s so you can roll back to 6.8.0 if there is an issue. It’s not required but you will have to go back to 6.7.x and upgrade tp 6.8.0 if there are any issues
