MVP Guru
Re: Clearpass - Using EAP-PEAP for selected AD users
You may need to look at access tracker > Input > Radius request and make sure that you have all the necessary attributes to match in the service.
Another thing you could try and do is use the Authentication:OuterMethod Not Equal EAP-TLS and see if it works.
Thank you
Victor Fabian
Lead Mobility Architect @WEI
Frequent Contributor I
John, you hit the proverbial nail on the head. Your explanation caused several puzzle pieces to fall in place.
I went back to a bare bones service condition and let the enforcement policy do the heavy lifting. It is now working like a champ.
Thank you all for your input!
