Clearpass and EAP-TLS
  • 1.  Clearpass and EAP-TLS
    Posted Nov 07, 2019 06:22 AM
    hello Airheads,
    we have a customer that wants to do EAP-TLS with non-AD clients and using their Clearpass.
    They are going to issue certs from an enterprise authority to the clients.
    I an thinking that i just need a copy of the root cert from their enterprise CA and install it on Clearpass and then set up a service to allow an EAP-TLS authentication for these non-AD clients.
    My question is do i need to specify an authentication source in the service?
  • 2.  RE: Clearpass and EAP-TLS
    Posted Nov 07, 2019 07:31 AM
    Use the CPPM local user db and disable authorization required
    Sent from Mail for Windows 10
  • 3.  RE: Clearpass and EAP-TLS
    Posted Nov 07, 2019 07:35 AM
    thanks for your reply Victor.
    I just wondered why you would have to specify localuserdb.
    What would it be looking up in the localuserdb?
    As far as i understood you just need a copy of the root cert.
    cheers
    pete
  • 4.  RE: Clearpass and EAP-TLS
    Posted Nov 07, 2019 08:27 AM
    In order to create a service you need to define an authentication source (the localdb is just a placeholder since you are doing cert based auth without validating the user or device)
  • 5.  RE: Clearpass and EAP-TLS
    Posted Nov 07, 2019 09:12 AM
    thanks Victor,
    appreciate you taking the time.
    we are going to use OCSP for revoction
    one last question.
    If the client certificate expires will it fail authentication with Clearpass?
  • 6.  RE: Clearpass and EAP-TLS
    Posted Nov 07, 2019 09:18 AM
    Yes
    Thank you
    Victor Fabian
    Pardon typos sent from Mobile
