Contributor I
Re: Clearpass guest captive portal, aruba wireless integration, controller access denied
Thank you all for your help.  It was much appreciated.
The issue was that guest network was not in a tunneled mode.
For those with the same issues please check the virtual AP profile, for this setting.  It was set to split tunnel which was working for the captive portal to the controller.
Thank you all again.
