Highlighted
Re: Clerpasss 6.8 Clustering Problem on ESXI 6.7
Did you check your DB cert? You may need to redo the DB cert with a SAN entry with the IP address.
SAN .    IP:ipaddress
Thank You,
Troy
Highlighted
Frequent Contributor I
I have fresh installations, no installed certificates, since when do I need for  clustering change default certificates SAN configuration?
Highlighted
As of 6.8 the DB cert is now in the cert services drop down. The cluster needs to also trust the DB cert to continue. I dont remember the whole details off the top of my head but the self signed cert has the hostname and the cluster join is trying by IP. If you put the IP in the SAN field it will join. I believe it was fixed in 6.8.1 but dont quote me. I just know a quick fix is to just use the CA in onboard and sign the DB CSR from both servers with a SAN entry with the IP address
Thank You,
Troy
Highlighted
One more bug, when upgrade clearpass from 6.7.10 to 6.8. Then change active system image back to 6.7.10, clearpass lose  VM activation token.
Action Status: This Activation Request Token is already in use by another instance
Product Name: ClearPass Platform
License Type: Permanent
User Count: 100
really?
I hope it will be recovered after  some time
Highlighted
Contributor I
Hello all,
we had exactly the same topology as written in the first post.
We were able to join the cluster usting the console command:
"cluster make-subscriber -V -i YOU.R.I.P"
Then the cluster join worked smooth!
Best regards
Highlighted
Frequent Contributor II
I tried this with command as you but it shown.
INFO - Check publisher connection passed
ERROR - Cannot connect to publisher database. Common errors include incorrect password, TCP port 5432 blocked, or invalid certificate.
No blocked, ping reach to each other.
Please advise.
Thank you,
Ratchapas S.
Land of Smiles
Highlighted
Hi
I can confirm
I had the same problem in GUI interface in CPPM 6.8.2
but with CLI command:
cluster make-subscriber -V -i <ip-address>
building cluster was ok
Don't know why from GUI there is a problem
regards
Karol
Highlighted
Hi Karol,
I tried CLI command but it did not work.
Thank you,
Ratchapas S.
Land of Smiles
Highlighted
This worked for me on ESXi 6.5 (below)
@kkarkowski wrote:
Hi
I can confirm
regards
Karol
Highlighted
Export the Publisher's HTTPS Cert and Database Cert into the Subscriber's Trust List. Since the export Cert is in .p12 format, please convert it to a .der format. Once that is done the clustering for 6.8.x shouldn be working.
