Highlighted
Re: Configuring management authentication for ClearPass against AD
Hi Cappali,
All AD users are able to access the Clear pass using their AD logins. Is it possible to only give access to Admin group?
Highlighted
Hi Cappali,
Any help re my last reply will be appreciated.
Highlighted
Highlighted
To be clear, the configuration that prevents anyone from logging in is the Tacacs Deny Profile here:  tacacs-deny.png
ArubaOS 8.5 User Guide
InstantOS 8.5 User Guide
Airheads Knowledgebase
Airheads Learning Videos
Aruba Central Documentation
ArubaOS Consolidated Release Notes
Aruba VIA ASE Solution - Configure VIA VPN
Highlighted
Hi Cjoseph,
Thanks for your reply. I have used the same article to configure the managment access for CPPM through AD. The problem is when I change the Defaault role to Guest or other as mentioned in the article none of the users from AD are able to login and I need the Admin users to be able to login.
I have also added the role to allow Admin users access but no luck. The only time it works when I change the default role to Read-only or super-admin but it allows all AD users same priviledges.
Highlighted
That probably means none of your mapping rules are matching.  What does your mapping rule screen look like?
Highlighted
Yepp, its looks same as the screen shot which you have privided, only my domain name and AD group is different.
Highlighted
That can only mean you are not matching anything.  I would open a case with support to check your work.
Highlighted
 Hi Cjoseph,
I have managed to solve the issue and now I can login to CPPM using AD admin account and normal AD users are not able to login.Please can you help me configuring a service on CPPM so that Aruba controller and Air wave server login through the AD same as CPPM?
Highlighted
An article on management authentication of Airwave using ClearPass is in the knowledgebase here:  http://community.arubanetworks.com/t5/AAA-NAC-Guest-Access-BYOD/Airwave-External-Auth-using-CPPM-RADIUS/ta-p/183348
An article on management authentication of an Aruba Controller using ClearPass is in the knowledgebase here:  http://community.arubanetworks.com/t5/AAA-NAC-Guest-Access-BYOD/How-to-authenticate-Management-users-of-Aruba-Controllers-via/ta-p/187358
Please search the knowledgebase for answers to any questions.
