I am running ArubaOS 8 with ClearPass Guest. I have a publicly issued certificate uploaded as my captive portal certificate on my controller(s). However, it has 3 alternate SAN's, one of which I would like to use for captive portal. However, show datapath fqdn only shows the primary common name of the certificate.
The bigger issue is that the controller intercepts all DNS requests for the common-name regardless of user role. If the user is an authenticated role via 802.1X (instead of guest) and they navigate to the FQDN, the controller always hijacks the request. This is a problem becuase the common-name of the certificate is being utilized elsewhere for other server access.
Is there a way around this behavior?
