Dot1x authentication pointing to Publisher or Subscriber?
  • 1.  Dot1x authentication pointing to Publisher or Subscriber?
    Posted Feb 05, 2020 12:39 AM
    Hi, We have deployed ClearPass cluster with one Publisher and one Subscriber for dot1x authentication for both the wired and wireless networks. We have enabled Insight on the subscriber and also OnGuard for endpoint health checks.
    Here my question is to which server authentication and OnGuard requests should point i.e. Publisher or subscriber. Shall we point all Dotx authentication request and onguard requests to the publisher as insight is enabled on Subscriber. we have C2000V platform with 5000 OnGuard license. Please suggest.
    Yugandhar.
  • 2.  RE: Dot1x authentication pointing to Publisher or Subscriber?
    Posted Feb 05, 2020 01:35 AM
    Both C2000V servers together handles 10000 concurrent sessions, you need to balance load based on number of authentication session requests.
    If request are less than  5K you can point request to publisher and set subscriber as standby publisher.
    All servers insight data will be sync with server with insight enabled.
  • 3.  RE: Dot1x authentication pointing to Publisher or Subscriber?
    Posted Feb 10, 2020 02:17 AM
    It is usually recommended to forward requests to subscriber nodes as much as possible. Handling requests is the purpose of a subscriber, its a worker node.
    In a two-node cluster, your publisher is already going to be busy processing some other stuff. You should use it as the secondary RADIUS  server on your NADs.
