Guest portal redirect to MSN issue
This thread has been viewed 22 times
  • 1.  Guest portal redirect to MSN issue
    Posted Jun 02, 2020 09:17 PM
    Hi All,
    Guest portal redirect to http://www.msftconnecttest.com/redirect and then ulimately https://www.msn.com/?ocid=wispr&pc=u477 ?
    Any idea how to fix this issue.?
    Model-7210
    OS- 8.5.0.4
    Cheers
  • 2.  RE: Guest portal redirect to MSN issue
    Posted Jun 02, 2020 11:31 PM
    Hi Dinesh,
    msftconnecttest.com is a standard Microsoft portal redirection method that forces if the browser can't reach the internet.
    Does It redirect to your captive portal for authentication?
    If you have a plan to mention a specific web page after successful authentication. you can mention when you create an SSDI profile.
  • 3.  RE: Guest portal redirect to MSN issue
    Posted Jun 04, 2020 06:54 PM
    HI Dinusha,
    thanks for the reply.
    this happens only when a machine is in a wired corporate network and then try to connect to the guest SSID.
    Dinesh
  • 4.  RE: Guest portal redirect to MSN issue
    Posted Mar 11, 2022 10:50 AM
    Same question.
    So I have a landing page and a page for successful authentication.
    It's unlikely our wired corporate device/users would try to connect to the guest SSID but is there a way to control this forced page rather than have a msn?
    Leo.
    Leo Pickford
