Hi there,
We have IAP-315s on aruba central, I'm trying to get a guest wifi network, with internal captive portal to work on a vlan which isn't the default vlan.
The captive portal asks you to accep the T&Cs, then it connects, very straight forward. I can get this to work on the default vlan, but then I start to run out of IPs on that subnet, because its also where most of the computers, printers, etc are.
I want to use 10.1.40.XXX as my guest vlan, but when I set the guest ssid to use this specific vlan, once connected to the network it fails to load the internal captive portal page, so it never authenticates.
I've also tried setting the same guest ssid to just use open security, this works fine, devices can connect and get the correct 10.1.40.XXX address.
What would be stopping the guest vlan from accessing the internal captive portal page? All of our APs have the Guest Access subscription applied to them.
