Could you explain this in a bit more detail please
Original Message:
Sent: Dec 11, 2019 04:09 AM
Subject: [How-to] Send auto login link via SMS for ClearPass guests
Use case:
A customer wants guests to self register using their mobile number and after registration they'll recive an SMS message with a one click auto login link.
Steps:
- From Guest > Configuration > Receipt > Templates > SMS Recipt
- add the link of your guest portal page plus
?username={$u.username|escape}&password={$u.password|escape}
For example: https://clearpass.arubademo.net/guest/login.php?username={$u.username|escape}&password={$u.password|escape}
- From Guest > Configuration > Pages > Guest Self Registration OR Login pages (depends where your login page is)
- Add to the HTML header of the login page the following script
{literal} <script type="text/javascript"> window.onload=function(){ var myEle = document.getElementById("ERROR_"+_form_name+"_user"); var myusername = document.getElementById("ID_"+_form_name+"_user"); var mypassword = document.getElementById("ID_"+_form_name+"_password"); if(myEle == null && (myusername.value!="" && mypassword.value!="")){ var auto = setTimeout(function(){ autoRefresh(); }, 100); } function submitform(){ document.forms[_form_name].submit(); } function autoRefresh(){ clearTimeout(auto); auto = setTimeout(function(){ submitform(); autoRefresh(); }, 1000); } } </script> {/literal}
The script will auto submit the login form based on those conditions:- Username and password exists
- No error message is visible (to avoid loops)
